bought boat with this condition. Operated boat all summer with no issues. Looking to fix for next. Dont know much about this but heres a photo with the obvious issue. Any help to fix this for spring or would you leave it? 87 omc cobra 5.7
Somebody half-assed a repair there, do you have any water leaking in near the steering arm? Salt water boat? Is there play in the swivel joint inside that area?
what it should look like. You can't get that part from BRP but they are out there on ebay..
https://www.crowleymarine.com/johnson-evinrude/parts/55333.cfm?mdl=79T1GO
part # 28 in the diagram.
If you can get that cover the seal and the bolts and replace it. Try lifting the drive up and down and see if there is play in that area. If it’s tight then replace the cover and seal and see if you still get water inside....
Definitely not normal!
