Blueghost924
- Sep 19, 2013
- 250
Hi-
I have a 1987 Mercruiser 5.7 L V8 with the Alpha 1 sterndrive setup. Earlier this year (around June), I adjusted the upper and lower shift cables to the specifications in the book. Going into forward, it shifts just fine, but it's always been "problematic" going into reverse. Up until last month, the sterndrive made a loud groaning noise while shifting into reverse...but it would still go in reverse. Forward always shifted clean with a nice thunk. Now, when running the engine and shifting in reverse, it makes a continuous "clank clank clank" sound. But it does shift into reverse. Yesterday, I watched Chris's video again on adjusting the shift cables, and verified the lower shift cable is exactly 6 inches from the barrel center to the connecting hole center. I didn't not mess with the upper shift cable. Also, the lower shift cable adjusting pin is set to the max height in the adjusting slot. I again ran the engine and testing reverse shifting. Now, the reverse is still making the "clank clank clank" sound, but if i rev it up (jump it up) to about 1200 RPM and back it down quickly, it will shift to reverse and the clanking noise goes away.
My adjustment checks have been done with the boat on the trailer, not in the water. And advice from here?
