Hi folks - It's the time of year I start tinkering with the boat in anticipation of spring and thinking about upgrades I'd like to make, one of which is the engine and drive.
Currently running an older 260HP Mercruiser 350 with an older pre-Alpha drive. Motor runs good, but is a bit tired. Always lacked grunt, or at least I always wanted a bit more. Drive has quite a bit of gimbal steering pin wear. Enough that I want to address it sooner rather than later. Its had issues with corroded wires and switches over the years but has been serviceable.
Anyway - In my mind what seems reasonable is to build a nice mild stroker in the vein of the HT383 crate motor and possibly re-using the manifolds, carb, distributor, and whatever else makes sense. I'd like to put a brand new Bravo in place of the Alpha but doubt that's in the budget. Seems a lot o wrecked/sunk boats out there with clean and newer Alphas should be available to part out?
Questions are, build or buy crate engine? Where to look for a clean used drive and what to expect to pay? Buy a clean used transom plate and buy a SEI drive?
I'd likely run my motor until I had everything in hand, then sell my set up and install the new one to recoup what I could?
Boat is a 233 formula. I' don't beat on it and would think a Alpha would be fine with a gentle throttle hand?
Any and all feedback and ideas welcome!
Thanks!
Thanks!
