FreeBeeTony
- May 15, 2002
- 3,995
Which is preferred in salt water?
Zinc or Aluminum?
Zinc or Aluminum?
Kinda surprised/comfused......can't quite understand why an aluminum anode would be used on an aluminum outdrive...![]()
The short answer is most aluminum is not aluminum.Kinda surprised/comfused......can't quite understand why an aluminum anode would be used on an aluminum outdrive...![]()
...As long as the anode has a higher nobility than the out drive, your good...[/URL]
You are correct.Errr, no. You want the LEAST noble metal to be the anode.
