sorry...I don't see in my profile where I can put this info...it's a bravo III...also, I put new trim sensor and limit senders on the out drive when I had it pulled off and the engine out....the sensor seems to be working fine but the limit is not...have never adjusted one before...I'm looking on you tube and found one thread....almost looked like when you had it close ( mine was going out to 26" so that mystery is solved) you could move the sensor to dial it in to where you want it, correct? With out actually hitting the trim button on the helm right? Mine is not doing anything....I did have the pump out when to motor is out...the wires from the out drive I verified are connected....I don't recall undoing much on the pump itself.....at least I can use the up and down on the position to keep it from going to high and using the boat this weekend, will just have to be carefull with it. But that is the way it is supposed to work, right? Turn the sender and it will work the pump?
I did a quick look of the wiring at the pump for the limit and it looks to be good...I don't see a real trouble shooting method in the manual for it....and my electrical is not so good.....so I know what the max dimension should be at the limit and then you have the trailer position...how much further out do those rams go for that? I'm not sure it ever worked to be honest...half the time the button would not work and I'd have to hit the trailer to bump it up to trim....seem like the regular up and down is working just not the limit.
