achris
More fish than mountain goat
- May 19, 2004
- 27,468
Both solenoids are the same. They both have a red cable on one terminal and either a blue (UP) or green (DOWN) cable on the other. When a solenoid is 'picked' it feeds power to the winding in the pump motor...So, each solenoid has 2 large terminals (power on one and either UP or DOWN on the other) and 2 small terminals (ground on one and either signal for UP or DOWN on the other)...
Here's a 'cutaway' of a solenoid. When 12v is applied to the small terminal (and the circuit completed by the ground connection on the other small terminal), the coil around the centre becomes an electromagnet and pushes that disc up to the 2 large terminals. That shorts them together and sends 12volts to the trim motor winding (of which the other side is connected to ground to complete that circuit)...It's just a switch that uses a low current to supply power to high current devices. Same as a starter solenoid.
Chris.....
Chris.....
