Renken1600
- Feb 10, 2019
- 46
Hey guys,
I have a Morse Incom Throttle box linked to a 1990 Mercury 115 two stroke.
When I pull the throttle out for neutral/warm up, the throttle is easy to operate and smooth. When I use the throttle (per its usual function) it is quite stiff...
Would one stand to reason that one cable of two is bad? I will disconnect the throttle from the outboard side and see if things change... if not, I will need help finding cables for both.
Cheers!
Parker
Cheers!
Parker
