Hello guys, I have a Mercruiser 350 Mag MPI. I do not know the serial number because the engine block was put on acid to be cleaned and the acid corroded the serial tab. But I am sure it begun with 0W... some of the earlier. I have the crankshaft sensor position bad. My engine do not use sensor in the distributor. I bougth one Chevrolet Bazer crankshaft position sensor here in Venezuela, were i live, and phisically it looks identical but it does not work. I am electronic engeneer, so I tested the failed one (it fails only at relatively high RPM) and the new one in my little home lab and discovered the following. The original sensor (failed) everytime I pass a piece of iron close to it, there is a pulse in the output pin. But the new one, one time I pass the iron, and it output a pulse, but the next pass do not output a pulse. I mean every two passes of the iron it output a pulse. Of course my engine does not work wjth this. The next thing I did was to buy another sensor on ebay, what is suppose to be a replacement for the 864297001 that is the original part number, and when I receive it, it works like the one I bougth in Venezuela, one pulse every two passes. So, now I am afraid of keep buying more sensors. I do not know what sensor to buy. Does any one have some knowledge about it and can help me? Here is the link of the sensor I bougth on ebay:
https://www.ebay.com/itm/PC123-For-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Additional info.: The original sensor has stamped this number: 12562910, and the one I bougth on ebay has 12596851
Thanks in advance for any help.
