Chris Matthews
- Apr 13, 2019
- 4
Hello, I’m looking for some help here. I pulled the engine out of my ski boat. It’s a 1990, mercruiser 350/5.7. I had it bored .030 over and rebuilt it reusing only the crank, everything else is new. I rebuilt the transom reinstalled the transom plate, and the gimbal bell housing and drive with new bellows and shift cables. Anyways, yesterday I reinstalled the engine and plugged everything up, and now I have no power to the dash, the only thing that works is the power trim because it’s wired straight to a battery. The grounding stud on the port side that holds the flywheel housing as well has the negative cable from the battery connected to it and a small black wire from the engine harness. Still somehow the boat is acting like it has no ground for anything else to work. Where should I start looking? Also I have a perko dual switch but the connections in it are good and both batteries are charged. I also checked for continuity from the ground stud to the battery - and it’s good. The manual wiring diagram looks like it says there is and engine ground stud as well as a flywheel housing ground stud. Thanks, also I don’t know how to add a photo to this post to upload the diagram, it says file is too large?
-chris
-chris
