Whew, glad we got that settled. Never mind the mark on the throttle cam, it is the mark on the pulley that needs to align with the safety switch plunger. Also align the flywheel mark. Don't make it complicated.
I started it up. The cylinder to crankcase drain hose is cracked and spraying fuel out. That is the only hose that I did not replace back in 2015. I think that is a bad sign. Why would that hose have pressure in it and why would it be full of fuel?
Since my last post I made the following adjustment:
I took the plugs out to help make timing easier. Number One plug was a little loose and had some fuel leaking out around the threads.
Before removing the timing belt I checked the timing mark with the flywheel on the correct marks and the the magneto pulley mark was one tooth to the right of the safety switch plunger.
I removed the timing belt and checked the points and found they were gaped at 0.020" but the light was going out 1/4" prior to the mark rotating clock wise. I then set the break point of the points with the light going out on clockwise rotation when at the correct marks on each point. I then measured the gap with feeler gauge and that puts the gap at 0.016" The only way to make the gap 0.020" puts the light going out 1/4" prior to the marks rotating clockwise.
I put the timing mark with the flywheel on the correct marks and the the magneto pulley mark I set just slight to the left of the center of the safety switch plunger about 1/16" to the left of the center of the plunger.
I removed the low speed jets on the carb and found 1 fairly large particle of black rubber in each jet cavity. I removed the drain plugs of the carb and blasted out with carb cleaner and compressed air and got quite a bit of black particles out of the carb. I repeated with carb cleaner and compressed air until no particles were coming out.
I left the float level alone as it was already adjusted just like the diagram holding upside down float parallel with the body edge of the carb.
I adjusted the linkage syc between the carb and the magneto but it was very minor adjustment to get the carb fully open.
I have new fuel tanks but I cleaned it out anyway. Mixed the fuel 48:1. I know the manual says 24:1 but reading many post there are a lot of people using 50:1 in the motor with no problems and I wanted to reduce oil in my water tank (trash can).
I adjusted the low jets to 1.5 turns open.
The prime squeezed up and nice and tight and held prime.
No fuel line leaks. The fuel lines are new in 2015 ethanol resistant.
The motor started right up and seemed to be firing on all cylinders and it did not lean sneeze. I ran a little rough ran OK but ran at high idle and did not die. I let it warm up at high idle and it started cycling rpm up and down almost close to stalling. I adjusted low speed jets in 1/4 turn and almost stalled. That was when I saw fuel spraying out of the cylinder to crankcase drain hose. I double checked to the rest of the fuel lines and fuel pump housing etc to and found no fuel leaks on any of the fuel supply train or carb.
The drain hose is cracked on top of the hose just before it connects to the nipple on the front of the motor. The location of the hose is on the Starboard? right side looking from the back and runs right along the bottom of the mounting plate that connects the motor to the lower unit.
Should I just replace that hose? I am wondering if I have a cracked piston or ring and not worth messing with it?
