There you go.----No problem with the upper seal then.------Remove the 4 bypass covers.----Inspect pistons and rings.-----Might need 4 cheap gaskets.
I did not open the bypass covers yet.
I tested on the river today for about 40 minutes. 36 mph top end about the same as before. It runs much better than before. Acceleration from idle is fantastic and would certainly yank a couple skiers up quick. From crawling idle I opened it all the way up as fast as I could push the throttle and no hesitation at all very solid and fast acceleration. It was never like that even back in 1980s when my Uncle used to pull us skiing and he used 24:1 mix. I was not expecting that. It runs slightly better top end when the engine door closed (maybe 1/4 mph) but idles better with engine door open. I have the idle set too slow (just wanted to see how slow I can idle). It will crawl real slow but after about 2 minutes it starts loading up. I have room to take the idle up about 25 rpm and still be at no wake so I think it will be OK after I adjust that.
Shut it off and started right back up. I had it set on automatic choke the whole time.
It still sputters in the mid range but only when cruising and de-acceleration at about half throttle (not during acceleration). At that point it vibrates a lot from about 2200 to maybe 2600 rpm. Maybe a little worse than before maybe not it is hard to tell. At one time the mid range was much smoother noting that the mid range has always been a little rough. I suspect that is the point where the throttle cam changes. Not sure but might still need more magneto sync work.
I am questioning how I adjusted the arm coming out of the magneto has an adjustable joint (two bolts) then another joint elongated slot with a spring. I can make the adjustable arm meet the criteria per instruction manual with the spring joint in several different tensions. The way I did it this time was set the arm with as much tension on the spring as I could. Not sure I did that right but don't see anything in the manual about the spring tension.
