Couldn't find anything in the stickys on this. I need to change my fuel water filter separater.. the part that's there is a
PFF5510 filer.. anything special I have to do when changing? Fuel shut offs etc.. it doesn't appear once I remove it that fuel should be running anywhere... thanks for any pointers...
Ayuh,..... Welcome Aboard,...... I use either Napa 3225 or 3226 fuel filters, same filter, just one is ever so slightly deeper,...... maybe 1/4" difference,....
I pre-fill 'em 1/2 to 3/4'ers full to help with spillage,...
I also pull the oil dipstick to get a couple of drops of oil to lube the new filters gasket/ o-ring,.....
If yer fuel system is still stock, the anti-siphon valve at the top of the tank, stops any fuel flow without the fuel pump's vacuum,....
When removin' the old filter, I crack it loose with my filter wrench, then slip a freezer baggie up around it, 'n finish spinnin' it off, droppin' it into the baggie, 'n seal the baggie,....
At the dumpster, I tip the filter upside-down, 'n inspect the contents of the old filter, mostly lookin' for water,.....
