Ok guys my block number is 10066011 which is supposed to be a roller cam 4.3. The boat is an 85 Chaparal so obviously it's been replaced at one time.
being an '85, the motor most likely was a 3.8 that they swapped in a 4.3 later leaving the 3.8 dizzy
the reason I mention this, 1985 was the first year of the 4.3, however boats tend to lag about 6 months because of inventory.
if that is the case, then you have the wrong dizzy in the motor.
229 fires the cylinders like108-132-108-132 you should have, semi-even fire
4.3 fires 120-120-120-120, even fire
The 3.8 dizzy would have long internal tabs for the rotor to fire against, NOT for an even fire engine. It may well "work", but it isn't right.
post a picture of the inside of the distributor cap, the inside of the distributor and then look at the embossment on the side of the block for the serial number.
