As seen in photo below, how can i repair this leak i have on the tilt/trim line going into the cylinder? inside the blue circle is where it leaks. fluid comes out of the middle of the nut and outside of the tube. nut is pretty corroded in the cylinder and i cant seem to get it to budge with out stripping it. i also have next to no room to remove the other end of the hose, which is also very corroded and will probably strip trying to get that out aswell. what is the consequence of boating and just leaving the leak as in? any tips?
