justnutsandbolts
- Apr 19, 2019
- 6
Hi..first post, very much a beginner, I took on this project and replaced the rotted 36 gal RDS Aluminum tank, bellows and regular maintenance.
One issue I ran into is the block drain on the starboard side is closed shut with JB-weld and I cannot access with a drill to tap a new hole. I do not want to remove the engine, I am looking for alternatives in order to be able to winterize this boat in the future.
Boat is a freshwater boat in NJ, The JB-weld repair was done before winter and it has been sitting in a garage since: Block is OK. I actually just drained the port side after 6 months in garage and clean water poured out.
Some questions:
1- Is there an another accessible location where I can drill and tap a new hole for a new plug ?
2-Would it be OK to just drain all other hoses and the port side plug, then add Anti-Freeze in using bucket system with muffs while running the engine for a while to replace water with the AF?
https://imgur.com/a/2dxiFrs
Thank you in advance.
Some questions:
