JSki
- Mar 7, 2019
- 4
I recently bought a 2006 Tahoe Q6. It is in great shape and only needed minor stuff done. Took it out for the first time this past weeks and worked great. As I’m working through the little issues I noticed there isn’t an alarm sounding during startup . I found the alarm “box” under the dash and it had a purple wire coming out it with a ring type connector, but it isn’t hooked to anything. Clearly they unhooked it at some point but i don’t see an obvious spot to reconnect it. When I turn the key on and touch the purple wire to any of the hot wires on nearby gauges the alarm sounds until I turn the key off or take the wire away from the gauge hot. Before I just connected it to one of those hot posts, Can someone tell me where the alarm is connected under the dash? Or maybe a schematic of the electrical system?
Thanks
Thanks
