Finally got the heads back and on the boat. Runs great but at higher rpm it will overheat and wont cool off unless I shut the motor off for about 2 minutes and restart. Then the temp drops rapidly. Ive noticed if you are looking at the motor the left riser on the exhaust gets pretty warm while the right one stays cool to the touch. Also the dash guage doesnt always match the vesselview temp. I also removed the thermostat and I get the same results. Where should I look first? If im running at 3700 rpm it did rise in temp but not to overheating level. WOT is 4700 with the prop im running. Also worth noting I did change the impeller already. Had the issue before and after I changed it. Will not overheat on the hose at home.
