tlizakow34
- Apr 22, 2019
- 3
Cutting to the chase, I have replaced the entire electrical portion trying to isolate the issue but now I suppose I am still at square 1. My 485 seemed hard to crank, eventually not cranking at all. Things I have done in order:
1. Cleaned Grounds and all electrical contacts
2. New and bigger battery cables.
3. New battery 1050 CCA AGM
4. New starter with new solenoid
5. Outdrive maintenance to check engine allignment and binding. Realligned engine. (was off by mm's). New gear lube and waterpump impeller.
6. Soaked engine cyls in MarvelMystery Oil and in the crankcase.
All of these had micro improvements to the engine starting but it still has a 50/50 shot at not turning. Solenoid clicks but it seams the starter is not powerful enough? Brand new starter so unlikely especially since the old one did the same thing. I fear something internal (hydrolocking, bearings) but dont want to open it up just yet. Can turn by hand with a tire iron on the front bolt but hear a hissing sound from under the valve cover. Will turn over after I get the engine past compression stroke.
