How’s everyone doing, I’ll try to be as detailed and quick as possible. I’ve read just about every topic related to my problem, but am not finding the EXACT problem I’m having.
i have a 94 wellcraft 236 5.7 MerCruiser thunderbolt alpha one boat.
When the engine is above 3k rpm I get a surge/bogging issue. It revs in neutral, has plenty of power, and will get to 3k with no hesitation, it will also run past 3k frequently to WOT for a few minutes before it acts up. When it does start to surge it doesn’t shut off it just loses power and I HAVE to put the boat in neutral to continue. Just letting off the throttle and going again will cause it to surge full-time. After it surges and I go to neutral it takes roght off full power. Here’s a list of what I’ve done, I’d like to fix it myself but am kind of lost and figured this would be a place to start before I called a mechanic.
I replaced today;
the distributor cap and rotor
Plugs and wires
fuel filter/water seperator
disconnectes the fuel tank vent and blew thru it, was effortless
checked vent screen on the hull while filling up with 40gal of fresh fuel
its a Quadrajet carb, PLEASE HELP, thanks in advance.
I replaced today;
Plugs and wires
