Some of you may have read my earlier post on "what direction " does the thermostat go into its housing. Well I got the thermostat in and all back together. Was running the motor today to test for leaks and all appears good . Thank You . I noticed smoke coming from the water pump impeller cover on the OMC drive. I thought" now what the heck". I shut the motor down and turned off the water to the muffs on the lower unit. I removed the cover plate and could see the impeller internal housing cover was HOT . Waited for it to cool and removed it to find the impeller had no water in there, it was not wet . The impeller itself was wore down a bit and some melted plastic was hardened and seem to prevent the impeller from turning. I have never run the motor without muffs and a water supply. I did install a new impeller late last season and this really helped my temperature problems that were off and on. It worked fine . What could have happened ? I ordered a new cover , impeller, casing for impeller and all gaskets with wear plates . Kind of scared about putting it in and wondering if the thing will just burn this one up. Any suggestions? How can I tell on a I/O if the impeller is spinning? I thought I have heard/read that OMC do not like muffs , some disagree some agree . Which is it? How would one supply water to a I/O if not through the muffs? Thanks in Advance
