Ok, I'm at work for another week and a half, but did get a chance to do some more work on my boat before I left. I've been doing my best to do some leg work before I just randomly ask questions but I'm just overwhelmed. I'll start off with what I've done.
I cleaned it up good and took a few core samples of the stringers. Found one bad stringer and one questionable and can't see the point in only replacing one of the two anyways. So both stringers will be replaced. I'm leaning towards Coosa Board at this point as I don't need a ton of it and it will pretty much be permanent. If I'm going to have to cut out the stringers I also can't see the point in not cutting out the transom. It's just about a 16" x 16" square that's glassed in the best I can tell. There is another layer of wood for the transom on the exterior that is screwed through the hull from the outside and looks original design, but I'm not positive. So there is a 3/4" piece of ply glassed in then about 1/4 - 5/16" of glass (hull), and then another 3/4" piece of ply screwed on the outside and painted. Hope that's clear as mud....
I've also worked on the gel a little for a test. I used 1500 with a DA, then cut,buffed,and polished and followed up with a wipe down with F11 Topcoat. (I use it on my bike and they advertise it can be used on anything). I think it cleaned up really well, BUT.... there are some stress cracks here and there (some are long) and a couple of chips that will have to be repaired. I have concerns about matching the gel colors and can't decide if I need to just fill the cracks and paint instead. (hoping for some direction on this!!)
I've ordered a good deal of parts to get the Merc 650 and the cable/drum steering going. At this point, I feel like I need to put it in the water to see how it will sit in the water with the added weight from the 650 vs. the 35hp Lark. IF it's to heavy in the aft, I may look at putting a permanent fuel tank under the bow to get some weight up forward. I will have to glass in some supports if so and would like to do all/most of my glassing at the same time.... hence wanting to just get it floating and running BEFORE I get to tearing it apart.
Ok, now for the newbie begging..... I have been reading in the forums for over a week now and I'm just overwhelmed with info. I've payed particular attention to WoodonGlass's Flamingo and archbuilder's Sleek just because I like both of them and the detail in their threads. Guys and Girls, I realize that opinions vary, but they vary so much that I can't tell what materials I need to glass the stringers and transom in (Epoxy or Poly?... what brand??...CSM,cloth, 1708... ALL OF IT?? What is a "Cleat"? Wax.. no wax?? How exactly to you make PB????) or what materials I will need to repair the gel.... Epoxy?? Gel repair kit?? Paint... (Automotive?? Rustoleum??) I guess what I'm begging for is some educated direction on which way to go with the structural repairs as well as the gel repair (just an "I would do this.... " would be awesome) and what specific materials/brands to use.
All that being said..... I don't want to sound like a newbie that just want everyone to do his work for him. If I'm just getting ahead of myself, tell me. I can take the constructive criticism and realize that some basics have to be learned before help can be given. I feel like I understand how to do the physical repairs (for the most part), but I can't nail down exactly what I need. I was REALLY hoping to have this thing ready next season and at this rate it'll be next season before I figure out for sure what I even need to restore it!
ANY help will be received and greatly appreciated. I will post some pictures after this post.. I'm on my work computer and all of my pics are on my phone!
