briangcc
- Jul 10, 2012
- 2,417
Neat little boat.
IF it helps any....the MFG in my signature had the following setup for a transom.... Wood on the inside, attached to the fiberglass hull, which had another piece of wood on the outside. So it was a Wood-Fiberglass-Wood sandwich of a transom.
From what I recall. it was through bolted from outside to inside. Might have been adhered as well but I wouldn't know as we got rid of the boat before I could think of restoring it.
There was a small knee brace that ran from the transom down to the keel on the inside of the boat to provide additional support. I want to say it was 1" thick mahogany for the MFG. I believe that's what was suggested above to help reinforce your transom with the additional power and weight you're adding.
As for paint its your call. Most here are on a budget so painting with Rustoleum with hardener is much cheaper than plunking down $$$ on a gallon of bc/cc automotive paint along with all the associated primers for the selected paint system. **I might need to add another $ to my figure as last time I bought paint was back in the 90's and it cost me about $100 for a qt of Ford silver in bc/cc.
