jimmbo
- May 24, 2004
- 13,943
A lot of engines are timed, and linked and sync out of the water, It doesn't have to be running to set the timing, max, or pickup. The water pump should be getting water(muffs, tank, lake) so as to keep it from self destructing.
Idle mixture, and setting the idle speed need to be done with the engine under load(in gear with prop), either in a test tank, at the lake or river on the trailer deep enough for the boat to be not quite floating, or floating and tied securely to a very immobile dock. Setting the idle speed will require the throttle cable to be free, Once the set is set, the cable length will need to be adjusted to have some preload(pressure) to hold the linkage against the Idle Stop. Too little and a consistent Idle will not occur, Too much and it will be hard to shift out of gear
