Factory Windshield Weather Strip
DLNorth
What have you guys used for weather stripping when you've installed your windshields?
I have yet to find anything that seems close.
Dan
DLNorth
Up date - I think I was over thinking this.
I found some on-line pics of SS 16's and got close up's of the windshields, and see that they are likely just using maybe 1/4" x 3/4" solid foam w/adhesive back.
This windshield is new to me/the boat so I haven't/hadn't seen exactly what was there.
Dan
DLNorth
Thanks Scott, but those look like the seal between the glass and frame, I'm looking for the seal between the frame and console. I didn't see one in that list that was the obvious choice.
GA_Boater
When I switched out my original plexi for a walk-thru, I used the sticky-back foam tape. It seems to work OK. If you go this way, get the densest you can find. It compresses a lot.
Watermann
Sourced at Home Depot.
y4mjZBG8drpGNTB2squGjCCjTx0hn3aDJlwUb61C0Lf9rMVAKoi13EvklXRbBW1zbb3U3tTkoQ94NLrKGjJM1nDBkfnsm9XI2zdNs8ttS1jewqtQcic7fdkwZPnOthBkyCDwOdMg7nkaIIfNF54UVZ2O8tgb9JNGd5sQSKjXshmNfk3_0iD2XJM8WN2iLjSg90nR_9pieG1qVDkRnHu3ZCI4A
GA_Boater
I don't remember seeing that bag of non-foam, WM. I woulda used that instead of the foam weatherstrip.
A ten year guarantee is a lifetime warranty for me. :eek:
Watermann
Yeah the EPDM synthetic rubber should last.
