I recently purchased the boat,motor,trailer from an estate, that had been sitting for several years. purchased a new gas tank and fuel feed, and the 1989 johnson 20hp started up after a few pulls, but still wont stay running (a few caughs then dies). it has a engine-mounted primer (not a choke) so if you pump every 5-7 sec) it will stay running. clearly a fuel issue
I ordered a fuel_pump and carburetor rebuild kits, took a day to disassemble, clean out, rebuild both, blowout out all fuel passages with carburetor cleaner & air-hose (no obvious signs of fuel separation or any other problem). reassemble and Fired it back up, and same issue. ( Checked low-speed jet, and its at 2 full turns (4 1/2 turns) so that seems about right.
fuel line pumps up solid and stays that way, so no leaks. after babying it for 1minute, I Checked the plugs and they look ok (and dry).
Ive worked on small outboards before, but this one has me stumped. IMHO its clearly fuel-starved, but the rebuilds didnt show any obvious issue (before) and yet it still wont stay running (after rebuild), no change in symptoms..
Its gotta be something simple Im overlooking 0 any/all suggestions welcomed...
-Garry
-Garry
