Well model #18902b is a 1969 18hp, but have to agree that lower unit is an earlier model 10hp. Plate was switched.
By the way that little cover where it is leaking gives access to the shift rod coupler. If the motor is new to you, you should install a new water pump impeller. Remove the lower bolt in that coupler and remove the 4 bolts which hold the lower unit on, and it will drop down and off. The water pump sits on top of the lower unit. Remove the cover to replace the impeller. I wouldn't run the motor without a new impeller.
