I just replaced the input shaft seal. Took it out, and it did great.. it's been sitting in the driveway for 3 days and I've noticed its slowly leaking gear oil.. Its coming out where the unit splits.....can someone please help me with this??
If you tell us what drive you have it would make answering your question a lot easier. But in most cases its the water pump base seal, lower driveshaft seals, upper driveshaft seals, shift shaft seals
By Doctur, I got the national # from you on another discussion for the driveline seal. Do you have numbers for the other 2 seals? That way I can pick them up at my local parts store. Thanks in advance.....
Thanks achris , shift shaft seal it was. Back to being a happy boater... just in time for 4th of July too,. All you guys rock. This forum has helped me alot.....
