Hello everyone, I have a Bayliner with a MerCruiser 3.0L TKS motor. I just finished replacing the trim limit switch and sender after bringing it out of winter storage (failed at the end of last year) and got it on the water for the first time this season. The boat starts up great idles and moves in gear while in a no wake zone without increasing any RPMs. As soon as the throttle is moved to take the motor over approximately 1000 RPM, the motor immediately dies. This happens whether in gear or not in gear. If you repeatedly rev the engine while not in gear using the accelerator pump to shoot fuel down the carb, the engine will rev like normal up to normal RPM's but as soon as you stop constantly revving the engine and don't take the throttle back down to lower than 1000RPM (just above idle) then it immediately dies. If you return the throttle back down to neutral after your repeatedly keep revving it, it usually just sets back into normal idle speed and stays running.
I am wondering if anyone has any advice on what might be causing this? The boat was put into storage with a full tank of fuel with stabilizer in it. It seems like it is almost starving of fuel as it will run up the RPM range when you repeatedly revving the engine by actuating the accelerator pump. Any thoughts on this would be appreciated.
Thanks in advance!
Thanks in advance!
