2006 Searay 220 select with 350 Mag
while under power the engine will cut off randomly but always fire back up. I installed a fuel pressure gauge and found that the fuel pump actually (audibly) cuts off and fuel pressure drops to zero. Sometimes it will die completely other times the pump with cut back on and engine run fine until it happens again.
I have a Mercruiser computer and no codes are present except for a random fuel pump relay ck code a week ago in which I changed the relay on the water and it did not fix. Lately it has taken atleast 45 min of riding to duplicate the engine cutting off at speed. I have not checked for 12 volts at the fuel pump when it does die.....with the information given does it sound like a failing fuel pump or do I need to check for voltage when it does die? I have a video of the pressure gauge if someone can tell me how to post it.
