Makes sense to me. So the oil pressure sensor was only used to turn off the fuel pump on older model boats..?
If I run the voltmeter from fuel pump positive to fuel pump negative and show no voltage. Then if I run volt meter from fuel pump positive to negative on the battery post and still show positive then I will know it’s a broke ground. If voltmeter from positive at fuel pump to negative on battery shows no 12v then....
Anyone know the part number for the Mercruiser fuel pump relay repair harness for 2006 350 mag
