Piston Sleeve Replacement
Evin South
Hello fellow boaters-
I have a 1981 35hp Evinrude with a bad sleeve.
It is correct to heat in oven, at temperature 475 to remove ?
Thank you for your time and responses.
Chinewalker
It would be far easier and cheaper to either bore your existing block or find another block.
RaisedByWolves
The sleeve is cast into the block and is an integral part unlike a dirt bike engine or a deisel.
Find a set of piston and rings and send it all out to a shop if you intend to repair it.
