It should be 1-1/2 by 16 TPI...Amazon has plenty of combo flywheel lift/removal tools. Mount it back in same holes as 90 as lower unit casting is the same.
Thank you sir.
Oh on the 2+2 operation. Compression was 129, 129, 129, 131 (per mechanic testing at the dealership where purchased and he wrote the numbers adjacent to the plugs on the water jacket when he tested it). I didn't really test it when purchased for my own reasons. When I got home and had time I went through it determining just what needed what. LU fluid replaced, nice and blue-black, sampled PTT fluid and crystal clear....ATF in this pump, and plugs were the alternate plugs for the engine and were in need of replacement. I put new NGK BUZHW-2 Surface Gaps back in, hooked it to a known, standby, fresh tank of 87 gasoline and lit it off yesterday on muffs.
I was really impressed with the smoothness of the operation. For some reason I expected a step function in performance at the crossover point but in looking at the linkage setup, by them using the fuel flow (analog) valve to feed 3 and 4, operated by the throttle linkage, and as the linkage moves to higher rpm settings, slowly depresses the fuel flow valve for more fuel to 3 and 4, they just smoothly start contributing to engine power increasing. Having never seen one I just thought they had a solenoid valve that would open at 2000 rpms.
Idle was much smoother than I expected and it "lit off" in a heartbeat with a little throttle and a few seconds of fuel enrichment. I think I will really like this engine. Thanks for the comments.
