Renken1600
- Feb 10, 2019
- 46
Hi everyone,
I am having a hard time figuring out the pitot tube and speedo hose routing. At the moment, my pitot tube is "clear" and it travels inside the lower unit, exits through a plastic square-ish elbow with a hose connected to it... essentially in front of the gear shift rod... just like the manual states.
Does it then just route itself in the boat to the speedo?
When I trimmed the motor all the way up, I discovered the end of that hose was slipped onto a super tiny rod for the lack of a better word. It sits just above the Primary piston (if this makes any sense). The photos show the elbow, the rod (looking up from underneath the engine) and on top where I figured a hose is supposed to go in that hole but there is nothing.
I'd like to try and use the stock configuration and not drill in to the boat so any help would be greatly appreciated.
