Cleaned and tested the temperature needle gauge on the dash, works fine. Temp Sensor on block was bad. Replaced it with a new sensor. Applied teflon tape to the threads, connected the sending wire and turned on the ignition switch. The temperature gauge immediately reads around 150* with a cold engine without starting the boat. Any ideas?
(Note: after letting it idle for about 10 minutes, the temp reading climbs and reads about 240* from the 150*)
