Mercruiser Thunderbolt IV ignition system. Sometimes almost 13v on + side of the coil, sometimes 10.5v at the + side of the coil. When at 10.5v, no start. When at almost 13v, fires right up. New cap, rotor, coil, key switch and kill switch. If I take the purple wire off the + post that runs to the ignition amplifier, I get almost 13v. When I touch the purple amplifier wire back to the + post, drops to 10.5v and again no start (Note: This is intermittent and sometimes it actually still reads almost 13v and starts). There is nothing on and motor is not running, just key in run position. Every connect on key to the battery to the motor components and battery connections all cleaned. New battery too. Does it sound like the Thunderbolt IV ignition amplifier is bad and shorting or something? When it runs, runs like a champ. Thank you for any help you can provide.
