qube84
- Jul 22, 2019
- 2
Hello, I tried to look through some other posts to see if I could find my answer before creating a redundant post but I couldn't find exactly what I was looking for. I have a V8 Mercruiser i/o Alpha 1 (late 90's) that I noticed wasn't moving water with muffs on so I assumed it was the impeller. I bought a kit and thought I did pretty good with putting it back together but I don't think the shaft is lined up correctly. The prop spins freely and it won't engage into gear. Is there a trick to making sure that the shaft is inserted correctly or did I possibly mess something up with the impeller install? I have not put gear oil back in since I'm guessing that I need to drop the lower unit back down again. Thanks for any advice you can give.
