- Jul 18, 2011
- 18,285
Last year the water pump on my 1969 Merc 7-1/2 hp crapped out (S/N 26346XX). No big deal, I figured, I'll get a new impeller. I took the lower unit off yesterday and went about disassembling the water pump.
the thing looked more like a melt-down than just a simple failure of the impeller. It seemed that the impeller and the pump housing had melted a bit.
I have new parts on order for the pump, BUT . . . .
In the process of getting the old impeller out, it seems that the bronze/brass hub of the impeller has become 'fused' with the drive shaft.
I cannot seem to get the 'hub' (which look like a hex nut in the picture) to slide up off of the drive shaft like it is supposed to. FWIW - this driveshaft is not original to the motor - it is a stainless steel shaft from a 1980 version of the Merc 7.5
Just wondering if anyone has any ideas, tips, tricks to get the hub off. :noidea: I can see the 'pin' that acts like a key to turn the impeller with the shaft, but the hub itself seems to be one with the shaft . . . probably because of the apparent amount of heat during the 'melt-down' :noidea:
TIA for any thoughts on this. I don't want to try to cut it, fearing that I may cut into the driveshaft a wee bit.
I've been using the Johnson 4.5 in the meantime, but to add insult to injury, the Johnson decided to crap out yesterday
Me thinks it is a fuel flow problem, but that is a story for another time.
