As always, thank you for the advice and encouragement.
Despite work and lots of unexpected interruptions, I was able to make some headway on the transom. I ripped some scrap stock on the table saw to make an outline/template of the transom using snips for shaping and a hot glue gun to take everything in place. Can’t remember where exactly I saw this tip, but it worked pretty well.
I still had quite a bit a bit of fine tuning after my first cutout on a scrap piece of old underpayment I had, but I finally got it to what I believe is “close enough” so that I have a nice even amount of space that I can fill with thickened resin.
After all all my adjustments I decided to go for it and cut out my two pieces of 3/4” plywood. I test fit them both, before pulling the trigger and laminating them together outside of the boat on my assembly table. I don’t have many have items for weighting, so I opted to pre-drill strategically placed holes and screw the panels together. I got nice squeeze out all around.
I am am still debating whether or not I am going to back the drywall screws out and replace with stainless screws permanently, or just take them out and fill holes with thickened resin when I start to glass everything.
On on a side note, I opted to not notch the cutout for the splashwell and motor until after all my final adjustments have been made now that the two pieces are laminated together...but boy is it tempting to think about how cool it would be to close in the transom right now!..I need to keep telling myself not to get side tracked, this is a fishing boat that is a quick and dirty turnaround to water ready.
