medburd
- Apr 23, 2003
- 18
Hi folks - been a member a while but this is my first post in a while and I really appreciate the knowledge I have gained from the vast knowledge base that you folks have shared - thank you!
I’m looking for opinions on what seems to be an outside the box thought (or hair brained idea you make the call
I had today while trolling fb marketplace. I’m currently restoring a 1979 17’ McKee Offshoreman. I’m in the process of removing all of the water logged foam in the hull. I will be replacing 75% of the deck and refoamin it with 4lb foam. I have come across an opportunity that had me
- I was originally planning on replacing the plywood deck w/new and epoxy/fiberglass the new plywood in place (just restoring pretty much as it was originally) drilling a few 2” holes in the new deck - tilting the boat at about a 30degree angle and pouring in the new foam to get it to conform & fill the void under the deck.
My new thought was the fiberglass pultruded grating I came across @ 2$ a sq ft @ 1” thick..which is comparable to plywood. If I went this route I could lay the grating down in place of the plywood - I could pour the foam between the grating rails to ensure complete foam fill - the foam will hold the grating down due to the voids it will fill as they’re I beam style costruction, then cut/level the foam where it expands above the grating, then fiberglass/epoxy over the foam and grating to create that water tight barrier - then a finish coating of whatever paint i choose later..
What do you guys think?
