This is a carry on from a previous post. I currently have TieDown brakes on my trailer and it's a 2005 trailer.
Looking at the condition of the calipers, I may rebuild them due to cost. Realzing I will have undo the brake lines to the calipers and looking at the condition of the connection between the steel line and the rubber line, the flare nut is quite rusty with a little rust extending on to the steel line itself. Overall, all flare nut connections are rusted.
I'm afraid things will break when I try to disconnect the connections so I'm toying with just replacing the brakes lines in addition to rebuilding the calipers.
I've seen rubber brake line kits. Are there any pros/cons in using an all rubber brake line kit versus the steel lines?
