Paguilar1986
- Jul 27, 2019
- 19
Hello everyone,
I have a 1990 bass buggy/tracker. On it I have a 1991-2 Stroke Johnson 25 hp motor. It works great, but the control box, where the fast idle lever and throttle lever are located needs some work done. The fast idle lever feels loose, and I’ve tried working on it, but someone told me that inside the control box there are plastic and nylon fittings that could have cracked. So here is my question.......
if I open up the box and do see parts that need to be replaced, Does anyone know of any online shop that might have replacement parts for the control box? Can I replace the entire control box with a newer one, if I can locate one?
Ive used Marine Engine in the past to order Replacement parts for my outboard motor. However, I know that this website usually only sells parts to service outboard motors. Where do you suggest I look for parts to help me with the controller box?
