If the plugs are out the motor, it shows spark on all 4 wires when cranking it over and using a spark tester.
Reinstall plugs, and start the engine, 1 and 3 have show no spark when hooking a timing light around the wires.
Motor has a new cdi pulse pack, new spark plug wires, new distributor cap, rotor button is still old.
Thought it may be a issue with the pickup sensor on the timer base but it checks fine with an ohm test. Tried adjusting the gap down further between the sensor and timing rotor but that resulted in spark on only 1 cylinder when running. Opened the gap back up and back at the original spark on only 2 cylinders.
Started it at night and do not see spark shooting anywhere.
Any ideas?
Any ideas?
