Bren118
- Sep 13, 2019
- 9
Hi everyone,
long tome reader, first time poster.
I just bought my second boat, a 1998 Mariah Talari 216 cuddy. It’s powered by a carbbed 5.7 mercruiser and an alpha one gen 2. I’m moderately knowledgeable when it comes to motors and did a lot of my own work on my first boat.
The mariah runs great. I engine noises, starts right up. No issues whatsoever running.
However, I noticed small drips of water coming from the stbd side of the motor when I had it on the muffs yesterday. Something I hadn’t noticed while checking is out at the seller’s house.
While trying to diagnose the leak. I made sure to check the oil, which is perfect. No milkshake, or signs of intrusion. I ran the motor on the muffs at 1000 and 2000 rpms and the drip remained the same frequency, 1 drip about every 3-4 seconds. It’s a tight squeeze into the engine compartment but I can feel one of the block drain plugs is very wet and the seam where the oil pan meets the bottom of the block is wet. It also looks like there may be a light streak of water coming down the side of the block. Makes me think the light steak of water is traveling to that seam and over to the plug where it’s dripping from.
I cant however, for the life of me find the definite source. My questions are. Could the block be cracked? Literally no other symptoms of a cracked block (I’ve dealt with that before). Or is there a common area that springs leaks around there? I also see next to the streak of water on the block other rust streaks were it looks like water has run in the past so I believe it has been like this for a while. Since it’s so slow and not a serious, flowing leak, should I just keep an eye on it and see if it gets worse? My wife thinks I’m freaking out for nothing and I hope I am.
thanks in advance for advice.
