The pump is on the motor so it can be dropped in, hook up and go
Another pump can be mounted about anywhere, but should be mounted low. Others have replaced cool fuel with Aeromotive, Weldon and others. If the return is routed back to the tank then no VP. Can also use another pump and not route back to the tank and just keep current setup. The regulator is what controls ther pressure.
Note: If a high output pump like Weldon or Aeromotive is used the return needs to go back to the tank. The high output pumps will push way more fuel then the motor will use so it can build more heat
It's obviously a lot easier for the boatbuilder to prepare the engine bay, complete with the transom assembly, battery and trim pump, then just drop the crate engine in and connect it up. Not so good for the poor fool who has to fix it 18 years later.
