I have a alpha gen 2 that is leaking drive fluid but I don’t understand how because of there the leak is. The fluid is coming out from where the outboard is mounted to the transom. There are no wet hoses or fittings anywhere that I can find. I followed the hose from the reservoir to the inside of the outdrive the from the outside of the outdrive and never found a leak. Is there something between the two haves that is leaking?
