- Mar 8, 2009
- 43,231
new sender is out of tank do arm length does not come in to play as I am moving up and down from full to empty by hand to see movement on gauge
I understand what your saying (the fuel gauge goes full to empty as your move the arm) but appears your not understanding my point.
Assume you tank is in the center of the boat. (I do not know how long the float arm is)
Being in the center, most tanks are not square or rectangular. They are more of a trapezoid. Deeper in the rear then the front, and also more shallow on the sides, and can have baffles.
So if the arm is longer and comes in contact with a baffle, it won't go all the way down.
If the arm should be front to front to rear and its is placed sideways, then it may not go deep enough.
Think of a triangle and picture the arm going sideways in the tank, the arm won't reach the bottom. Just one example. Same goes as if there is a baffle in the way
