Mercruiser 120
- Jun 17, 2018
- 75
I have a 2.5L Mercruiser 120. It would over heat if I run at speed, then I could slow down and it will cool down, so I idled at the dock, tested the flow coming from the transom, loads coming in. Then I took the hose that dumps water in the manifold from the thermostat housing and water would spout out there. I thought it was the manifold so I had a newer exhaust manifold at home. New gaskets for the intake and the manifold. Same problem. How is exhaust getting in where only the exhaust is supposed to be
