I think I know which questions you might be asking but would be better if they where just asked so we can cover them to the best of our non-expert options
Note these are all done with "IF" they are used, and not are used
Each metallic fuel line connecting the fuel tank with the fuel inlet connection on the engine must:
Speaks of material which must be used if metalic is used.
Each metallic fuel line that is mounted to the boat structure must be connected to the engine by a flexible fuel line.
Another if
Each fuel line from the fuel tank to the fuel inlet connection on the carburetor must:
If below level of carb
CFR 183.558
(2) From the fuel tank to the fuel
inlet connection on the engine must be:
(i) ‘‘USCG Type A1’’; or
(ii) ‘‘USCG Type B1’’ if no more than
five ounces of fuel is discharged in 21⁄2
minutes when:
(A) The hose is severed at the point
where maximum drainage of fuel would
occur,
(B) The boat is in its static floating
position, and
(C) The fuel system is filled to the
capacity marked on the tank label
under § 183.514(b)(3).
(c) Each hose must be secured by:
(1) A swaged sleeve;
(2) A sleeve and threaded insert; or
(3) A hose clamp.
View attachment CFR-2010-title33-vol2-sec183-558.pdf
The only boats where I have seen a metal line connecting fuel tank to motor are old ones. The motor and boat will vibrate/flex differently. A hard line will have more possibilities of stress cracks. My sister has a 70's model 52 foot Jefferson and it has hard lines leading to the motor, but rubber from the metal to the motor. There is a fuel shut off on the hard line. the valve is great for filter changes
Just my opinions, suggest contacting USCG for assistance
