ThomW
- Aug 8, 2016
- 615
Hey all. I've winterized numerous other Mercruisers, mostly smaller 3.0 engines. With the 7.4 is there anything additional I should do to ensure all the water is out?
No issues with changing gear lube, oil and fuel filters, oil, and winterizing the inside water system. My question is focused mainly on the engine block.
I know to pull the drain plugs, poke around to remove any debris, and I have a bucket I use to run anti-freeze through motor via a pair of ear muffs while its running, after I drain water.
Is there any additional steps I need to take? Like pulling hoses? removing thermostats? pouring anti-freeze into any hoses or anything like that? Do I need to do anything for this system specifically? Does it have a closed cooliong system I need to address?
Thanks as always!
Thanks as always!
