Kona fisher
- Oct 16, 2019
- 8
fuel delivery problem driving me nuts
About to Sinjin from a friend looks like it's hardly if maybe never been used but you wouldn't starts at first when I how does the fuel is flooded the cylinders with fuel but I adjust the floats and got that problem taken care of but now no matter every time I try to start it it won't start and there's good spark but I take the spark plugs out and there's absolutely they are absolute bone dry I know I changed the Jets on the carb I know that the carburetors got fuel in it and but for some reason it's not getting from the carburetor into the cylinders and I cannot understand why I know the Jets are clear I know there's fuel in the carburetor there's good compression it's like Satan's inside this outboard I even use a drill to turn it over and will not fire at all and when I look inside the cylinder there's just zero fuel it's from the carburetor to the cylinders any ideas? I've taken the carburetor off at least 10 times there are these little valves between the carburetor and cylinders they appears to operate just from the suction open and then closes them back. I have had many backyard mechanic look at it nobody figure it out I have sprayed starting fluid in carburetor but it doesn't seem to be making it to the cylinders either as there's no smell of the starting fluid in there and of course it's not kicking over almost does but it seems that with the lack of fuel not going to ever kick
